I have an '08 6.4L which is completely stock including the latest 1123b flash from Ford. My question is it possible to do a dpf/cat delete and ONLY turn off the regen with a tuner and maintain ALL other stock programming including the latest tightened protection parameters of the 1123B flash ? If so what programmer?
I have an H&S XRT pro and it gives you the option of tuning and stock horse power. Now I would think that it only does the regen cancel when you select stock HP but not positive. Check with Nate at Performance Truck Products DSTRBD on hgere. Hope this helps
BUT does it re-write the stock file with a modified version of the latest Ford flash just removing the regen ?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
