H&S MINI? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-22-2011, 04:35 AM Thread Starter
sledfreak's Avatar
H&S MINI?
So if you load a tune on the mini and then you take out the sdi card,will the gauges and the tune function properly.
08 6.4 250 cc sb lariat loaded white/tan 4x4
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
sledfreak is offline
post #2 of 6 Old 05-22-2011, 04:38 AM
I think so but why would you want to. The mini doesnt even need to be plugged in to work.
2008 F-350 King Ranch 6.4
H&S Mini Maxx
AFE Stage 2 intake
DOC/DPF delete
MBRP 5 inch exhaust
geereed is offline
post #3 of 6 Old 05-22-2011, 04:42 AM Thread Starter
sledfreak's Avatar
So if it was stolen,i wouldn't loose the chip with all the info on it.
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
post #4 of 6 Old 05-22-2011, 04:48 AM
You can backup all the files on your card to your computer or you can download all the files from the H&S site. So even if you lost the card you could just download the files and put them on any micro sd card and your good to go. There is nothing on your card that you cant download on the H&S site.
H&S Mini Maxx
AFE Stage 2 intake
DOC/DPF delete
MBRP 5 inch exhaust
geereed is offline
post #5 of 6 Old 05-22-2011, 04:53 AM Thread Starter
sledfreak's Avatar
ya, i never thought of that,i quess i should do the kem card to.It should back up the stock info to right?
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
post #6 of 6 Old 05-22-2011, 05:07 AM
Yes. I have 3 or 4 cards with different tunes plus i have them backed up on my computer. I was told there is no backup of the stock info on the card so at any time you could just get all the files you would need to return to stock and tune from there site.
H&S Mini Maxx
AFE Stage 2 intake
DOC/DPF delete
MBRP 5 inch exhaust
geereed is offline
