- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
The older SD's were easy - one blower - but where should a pyro be installed on the 6.4 twin? My DRW CC is okay stock, but isn't the powerhouse I expected. If history has shown anything it's been obvious that programmers typically add mileage, and this beast need all the help it can get in that department!
| Sponsored Links |
my personal opinion would be the manifold before the first turbo. If I am correct the two turbos are hooked in line, as in one powers the other. If that is correct then my idea of where to put the pyro is correct. You would want it on the manifold before the first turbo. Because the second turbo should be running cooler then the first one. Maybe Marc or Scuffy, Of StrokeTech can give you a better Idea then my guessing. |
If it's post turbo the reading is a little bit lower but still just as good of a reference as the differential will be the same at any temperature. When it comes apart you won't need to buy new turbo's. Put a heat gun on the different places to see what you get. Last edited by DavidPhillips : 08-05-2007 at 08:05 AM. |
On my last truck, I had both pre and post turbo installations, so I think I can answer this question with FACTS. The post turbo reading can be as much as 500 degrees off under full throttle. The post unit was about as useless and inaccurate as it can get. While under consistant speed and throttle, the post temps were usually 200 degrees behind, but it does not reflect that difference under throttle spikes. As far as burning off, maybe a big rig with a few hundred thousand miles may experience probe failure with a stainless unit, I doubt that any pick up truck will have the same hard use. There are inconel alloy probes available which will hold up many times better than stainless, and stainless is pretty darn good! Personally, I've never had a problem.. |
perfectly stated couldn't agree more !!! |
| Sponsored Links |
