bullydog watchdog monitor
I have one and the pyro gauge seems to be stuck at 611 anyone seen this before ? Thanks in advance
Both pyro gauges show 611 with the key on truck cold and not running. pos I guess
well bullydog tech support tried to tell me that the dpf delete is the reason. The tech at performance truck products tells me the unit is bad. They are sending me another unit and so far their support is great.
I have one and the egt moves very very slowly and is basically useless to monitor has been from day one. called and asked bullydog about it and they didnt have a solution. the boost only goes to 30 as well and i know my truck runs more boost than that. i am very disapointed w this unit and wish i had never bought it, so let me know if they get urs workin. i sure would appreciate it
performance truck parts is sending me another unit. The tech Zack has one on his 6.4 and it works great. He says it is a faulty unit. I will keep you posted
Ok cool. hopefully that will fix u up then
Well second bully dog did the same thing. I finally went with an edge CS and all is well. CS reads the pyro in the turbo up pipe that ford puts there. Much better unit than bully dog IMO
