Air dog or Air dog II - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-22-2011, 03:50 PM Thread Starter
rockloader's Avatar
Ok gonna upgrade to an Air dog but which one do i really need to go with ? Im not looking for a race truck just a daily driver and hauling here and there. The truck will have a mini maxx exhaust and intake and for now the dpf stays. I did notice that the Air dog II replaces the oem pump is it worth the extra to upgrade the pump it will provide more than my truck will need. Thanks
2008 F250 cc lb 6.4 auto
stock for the next few weeks
turn over ball
Work truck
2008 KW T800
525 ISX High torque 1850 ft lbs
18 speed
tri axle
rockloader is offline
post #2 of 6 Old 04-23-2011, 07:26 AM
08spartan250's Avatar
if you're going to leave the dpf on, there's really no sense in upgrading it at all. and even with the dpf off, these tuners push out so much fuel anyways. if you are looking to upgrade something, i would look into upgrading the air intake portion of the ratio.
-Mike
2005 F-250 Lariat
Originally Posted by azkcr View Post
And you didn't know Cummins can manage 127mpg??? They also deliver babies, go to Mars, and cure AIDS. DUH
08spartan250 is offline
post #3 of 6 Old 04-23-2011, 08:42 AM
eric.davis's Avatar
Send a message via AIM to eric.davis
If your planning on upgrading to an AD I would go with the ADII that way you have a better filtration and it will be much easier to change your filters.
2011 Dodge 2500 6.7 CCSB SLT
'08 F-250 with some stuff done
545/1050 on #2 SOLD
eric.davis is offline
post #4 of 6 Old 04-23-2011, 08:57 AM Thread Starter
rockloader's Avatar
thanks guys thats what i was thinking was the ADII deffinately need the extra filtration around here
turn over ball
Work truck
2008 KW T800
18 speed
tri axle
post #5 of 6 Old 04-23-2011, 01:28 PM
I've been looking at the AirDog II as well.
I know Ford uses a 10 micron filter on the frame rail and a 4 micron on the engine.
Does anyone know what the AirDog comes with? ... I can't find any info on their website.
tensixniner is offline
post #6 of 6 Old 04-23-2011, 03:53 PM
eric.davis's Avatar
AirDog Replacement Filter Options
- Replacement AirDog Fuel Filter 2 micron (Part Number FF100-2) for all AirDog and AirDogII units
- Replacement AirDog Pre Filter (Part Number WS100) for all AirDog and AirDogII units
Select the filter options from the drop-down menu selection to add the items to your shopping cart.
There you go bud
545/1050 on #2 SOLD
