What does it take to run 12's? - Ford Powerstroke Diesel Forum
Old 04-20-2011, 08:00 AM
Sorry if this has been posted numerous times but I have been searching and couldn't find anything on this.
I have an 08 4x4 4 door. Just did the H&S mini, dpf delete, and S&B CAI. What else is needed to run 12's or would I need fuel and turbo upgrades. Not interested in running nitrous. Also what are my current mods good for at the track? Thanks for the help
Old 04-20-2011, 08:42 AM
I ran 12's with just an intake, exhaust, and the Spartan 310 tune. That was on 35's and a leveling kit. I have since gone 12.4 with the Spartan 310 on fuel and with minor upgrades.
1. SunCoast transmission and torque converter (and Spartan TCM)
2. EGR cooler delete and CFM+ intake elbow
3. Elite ported fuel rails
4. Air Dog II DF-165 (not needed)
5. CalTracs traction bars
6. Toyo Proxes
7. Big weight reduction (got my CC/SB down to around 7700-7800 lbs with me in it)
Old 04-20-2011, 08:47 AM
Thanks for the info. So I should have no issues running some 12.9's low 13's in good weather on a 260hp tune correct?
Old 04-20-2011, 09:12 AM
Yep, you should be high 12 to low 13s with a good launch and a decent track.
Let us know how it goes!
Old 04-20-2011, 11:04 AM
Good deal. So what are some of the succesful launching teqniques yall are using?
Old 04-20-2011, 04:04 PM
Try boosting at 1800 See how that works run like 40lb in the front and 35 in the rear.
Thanks Dale
Old 04-20-2011, 04:37 PM
I can't speak for others, but I put the truck in 4-hi get the boost to 12 PSI and let her rip. Anything above 12 and I start to overpower the brakes. I am planning on hitting the track with the new 300 tune and see what it can do.
Old 04-20-2011, 05:37 PM
I can launch at 20-22 psi, but the sweet spot for me seems to be 16-18 psi. Anything above 18 and the front starts hopping.
Old 04-21-2011, 07:11 AM
Ok so just to make sure I have this right. Put the truck in 4hi and leave it there throught the run..?? I assume that is right but just wanna make sure.
Also as far as brake boosting goes. With a few of the Lightnings that had turbos on them we would use the e-brake and rig a little wire to the release handle. Worked great to help build boost since they did not make a transbrake for the 4R100.
Old 04-21-2011, 02:26 PM
I put mine in 4 hi and lock the hubs. Once I am through the traps, I turn the electronic 4wd off. I leave the hubs locked the entire time I am at the track.
Not sure on the break boosting. I just hold the break, build boost, and release when the tree drops.
