h&s mini - Ford Powerstroke Diesel Forum
Old 04-19-2011, 05:25 PM
h&s mini
I have had it on for a week haven't pulled the dpf off yet,tonight on the way home from work the check engine light came on,got home shut it off turn the key back on to check for codes and it said no dtc,but the light is still on,any thoughts.
Old 04-19-2011, 05:40 PM
You may have tripped a DTC that was only active for a few seconds. If the DTC clears/heals itself, it is possible that it will leave the light illuminated for a few drive cycles, but report no codes to the H&S Product. I suggest clearing the codes anyway, so you don't have to see the light on for XX drive cycles.
Old 04-19-2011, 06:10 PM
Ya,i hit the clear button,then hit the back button,then back to display,fired it up and still engine light.So you say it will stay illuiminated for a couple of drive cycles,okay i will give it a couple of cycles and see how it goes.
Old 04-19-2011, 06:34 PM
You may be throwing a DTC from another module. The H&S products currently are communicating only with the ECU. We are working on some new software that will allow us to do a global module diagnostics check. For now, I would recommend updating your tuning device, and driving for a couple of days. If you still have the light, return the tuner to stock and drive for a while to see if the problem presents itself in stock form as well.
Thanks!
Old 04-19-2011, 10:48 PM
I was having the same problem this morning along with other issues that were on my end. I ended up downloading the full sd card firmware and updating my device and truck. Make sure the uncompressed files are around 433MB or you will get the CEL. Im still having issues with the hot damn tunes load, but I've got the regular tunes on lockdown.
