DPF delete installed, need sensor Part numbers please! - Ford Powerstroke Diesel Forum
Old 04-15-2011, 10:02 AM
so i did a little search last night after installing my 5" Flow-pro turbo back exhaust.. deleted everything.. but has the bungs for the sensors.. the probe at the back of the DPF would not come out.. i tried everything.. so i need that one to put in the new exhaust cuz right now my truck idles right around 900-950 rpms.. w/o that in there.. i also need the brass looking sensor (back pressure maybe?? ) i dont need the bracket.. just the sensor itself, somehow the threads got messed up while taking it out of the stock exhaust.. i did a search on the forum but its unclear which one is which.. i was trying to find a diagram.. but no luck.. are all 3 of the temp probes the same part number??
I love the way the truck runs w/ the new intake, sct livewire and exhaust.. just need those 2 new sensors so the idle will come back down.. thanks!
Old 04-15-2011, 03:17 PM
I manged to get 2 of the 3 sensors out when doing mine. It ran fine, with no codes for a few miles but then the codes started popping up. They stayed on the dash until I replaced the sensor. The truck ran fine the entire time though. You will need to go to your Ford dealer to get the sensors. Autozone, Discount, O'Reilys does not have them, I tried. I believe my sensor ended up being around $30.00. Good luck!!!!
