H&S Mini Maxx Settings - Ford Powerstroke Diesel Forum
post #1 of 24 Old 04-14-2011, 02:31 PM Thread Starter
RachHandinit's Avatar
I just got all my stuff in today from Nate at Performance Truck Products. Ended up getting H&S mini, afe PDS intake, and 5" flo pro with muffler. I can't wait to put it on tomorrow. I was wondering what the best settings on the mini maxx are for daily driving?? I know to set the TC at 45 from what I have read but what are some other main settings that have worked for yall?
Also is the wild setting best for towing?
RachHandinit is offline
post #2 of 24 Old 04-15-2011, 03:43 PM
shapiros's Avatar
Have a similar setup -5". I have found "wild" best MPG for daily driving. However, "mild" seems to be better for towing any kind of load (smoother power, egts lower, etc) but could vary. I set the de-fuel parms at 38 for boost, 1200 for egt, 170 for engine oil and trans fluid.
Also, the guys at H&S warned me about the "surging" with the 45mpg TC lockup. Takes a while but you eventually avoid the point it shifts naturally.
Good luck! You'll love it!
Sig
2010 F250 FX4 Sterling Grey CC SB 3.31 Gearing
  • 20" Pro Comp Wheels
  • 34" Nitto Terra Grapplers
  • Ionic step bars
  • Husky Liner mud guards
  • ReadyLift leveling kit
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
  • H&S Mini Maxx Tuner
  • Flo-Pro DOC/DPF delete
  • AFE Stage 2 Pro 5r intake
  • HID Bi-Xenon 55W, 6000k temp headlights
  • Complete LED interior/exterior lighting including front switchbacks
  • Webasto 4300 sunroof
  • AmSoil (engine, trans transfer and diffs coming)
shapiros is offline
post #3 of 24 Old 04-15-2011, 04:03 PM
Trogar's Avatar
I have a 4" set up, use Hot with the HOT DAMN DL installed for everything. TC set to 45. You are gonna love this set up! I do! Makes this truck an animal.
2009 F350 Lariat 4x4
S&B CAI
H&S MiniMaxx
4" FloPro Straight Pipe w/o muffler
5" Black MBRP Tip
18" Fuel Octane's
35" Wrangler DuraTrac
AST UltraStart 2280 XR Command Start
Trogar is offline
post #4 of 24 Old 04-15-2011, 07:02 PM Thread Starter
Sig
What do you mean by surging with 45 TC?
post #5 of 24 Old 04-15-2011, 07:15 PM
Dim Sum's Avatar
Send a message via AIM to Dim Sum
I have my mini set up with the 45TC. Only think is it really doesn't want to be driven at 45 MPH. Keep it below 42 or above 47 and you are fine!
Don't forget your defuel settings! As far as I'm concerned, keeping those set at a moderate level helps ensure you safely drive the truck with less risk of damage.
-Steve
2011 F-350 Lariat 4x4 SuperCew: White Platinum Tri-Coat, Goodyear Wrangler Silent Armors, Window Tint
2001 Hyundai Elantra: Daily Driver
2007 Polaris Sportsman 700: Weekend fun!
Dim Sum is offline
post #6 of 24 Old 04-15-2011, 07:52 PM Thread Starter
Can someone explain the TC lock up a little more. Dont really understand. Should i stay with the default lock up or customize it?
post #7 of 24 Old 04-16-2011, 04:10 AM Thread Starter
Alomg with my question above, what is the best way to re-learn your transmission quickly? Should I follow the manual that says:
0-60MPH @ 1/4 throttle position, then slow down and come to a complete stop
0-60MPH @ 1/2 throttle position, then slow down and come to a complete stop
0-80MPH @ wide open throttle position, then slow down and come to a complete stop
or do something else?? Any info on these two question will help.
Thanks
post #8 of 24 Old 04-16-2011, 05:22 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
what is the TC lockup on a stock truck?
strokinpower is offline
post #9 of 24 Old 04-16-2011, 06:29 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
i ordered the exact same thing....then it was pointed out to me that i couldn't read my EGT's without the pyrometer setup.......now i think i need to return my tuner for the other one....which one did you get?
INJEKTER1 is offline
post #10 of 24 Old 04-16-2011, 07:05 AM
FastStrat's Avatar
According to the H&S website the 6.4 EGT's are readable through the OBDII port...you shouldn't need an external Pyro probe.
Just because you bendin' strings...doesn't mean your playin' the blues.
FastStrat is offline
