Dealer replaced HPFP and problem still persits. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2011, 01:36 PM Thread Starter
Unhappy Dealer replaced HPFP and problem still persits.
I posted this in the 6.4 motor problems forum with no response. Hoping I can get some help here.
took my 6.4 into the dealer 3 weeks a go for loss of power and check engine code p0088 (fuel rail/system pressure) too high. tech said it needed a new hpfp and so they went ahead and replaced it. truck seemed to be ok when i got it back except whenever i got back into the truck after driving it for a while there would be a loss of power right when i started it up and got going. id get on the gas and it would just have no power but would then clear up pretty quick and start driving normal. this always happens everytime i get back into the truck and get going. now im getting a p0087 (fuel rail/system pressure) too low and p2291 (injector control pressure) too low-engine cranking. im not always getting a check engine light but i can feel the truck running funny and when i run diagnostics on the dashdaq, those are the codes its producing.
can anyone tell me whats goin on?
OC Stroker is offline
post #2 of 8 Old 04-13-2011, 11:35 AM
KTMotoRider1's Avatar
Im assuming you got it fixed under warranty? take it back and tell them to get it done right!
Ford F250 6.4 CC/SB, Spartan 350 w/TCM, Mag-Hytec deep pan, Flo-Pro 5 inch Exhaust, AFE stage 2 with ProDRy, 2.5 Readylift, ZEX Nitrous single stage, BD CAC pipe, ATS 5-star converter, elite egr delete/wastegate, ts mp-8 stacked, Procomp traction bars, locker, CFM plenum, ARP studs. Innovative tunes and Suncoast on the way!
KTMotoRider1 is offline
post #3 of 8 Old 04-13-2011, 05:43 PM
pyro2nite's Avatar
Try the easy route first. Fuel filters. May have pick up some dirty fuel.
2008 FX4 SC SB 6 Speed 3:73LS, Transflow, H&S Mini Maxx, KEM Tunes, S&B Intake
pyro2nite is offline
post #4 of 8 Old 04-13-2011, 06:56 PM
I had the HPFP replace by the dealer ....truck had 117k miles......after teh repair I never had issues...I thinking it could be the HPFP again....I was told it's a poor design of a HPFP. I would take the truck back and have it fixed under the the repair warranty...good luck and keep us posted....BTW the PO0087 and PO0088 codes have to do with the HPFP....
Smoke2008 is offline
post #5 of 8 Old 04-14-2011, 11:08 AM Thread Starter
bringing it back to the dealer next tuesday. funny thing is ive noticed these syptoms happen on every tune i have except for the 310 tune. i have the original production 310 tune and havent upgraded my tuner since i upgraded to the stratagey flash tuner. i reallly hope they can get this issue resolved. i cant tow with the 310 tune and i cant have this sh!t happening to me when im in the middle of nowhere with a load in the back...
post #6 of 8 Old 12-14-2012, 07:03 PM
Solved?
Hey bud sounds exactly what's happening to me.
Did you get it fixed? What they did wrong?
Steinbrenner is offline
post #7 of 8 Old 12-15-2012, 04:52 AM
Subscribed and good luck!
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #8 of 8 Old 12-15-2012, 05:16 AM
air in the in the fuel system?
lazlow is offline
