Nitrous Activation?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2011, 07:40 PM Thread Starter
Biggsw784's Avatar
I got a NX Diesel Nitorus kit with the control module and it gives me the options to activate the nitrous by throttle postion, rpm, or by boost pressure. What would be the best activation?? On our racecars ( on race gasoline) we activate it on wide open throttle by I would think it would be different on a diesel?? Any experience here would be appreciated!!
2008 F250
10" PMF Lift
38x15.50x20 Toyos
20x12 Fuel Hostage
AFE CAI
FLO PRO 5" Turbo-back
"Spartanized"
2004 F350
Leveled out
35x12.50x18 Nitto Mud Grapplers
18x9 Monster Wheels
5" exhaust
Diablo Sport Trinity 2
Big Tex Bed
Biggsw784 is offline
post #2 of 3 Old 04-10-2011, 03:35 AM
Beatngu's Avatar
RPM window switch is the best bet for safety. That way your already moving so it's not as much wear on the drive line. And if your tranny malfunctions and you bang the limiter you can set the bottle to shut off at your fuel cut off to avoid a backfire.
2016 AG GT350
2013 Fresh150
2008 F350 Lariat Stroker
2005 F250 Lariat Stroker
2004 Mach1 6 spd Black on black
DSS 5.0L stroker
Comp cams w/ FRPP ported heads
twin Turbonetics
13psi 749 hp / 620 ft. lbs. @ 16*
E85 numbers to follow
old Kenne Belle setup at 16 psi
and so on......
600 hp / 585 ft. lbs.
Beatngu is offline
post #3 of 3 Old 04-10-2011, 06:03 AM
Never had Nitrous on a Diesel. But I would still use a WOT switch and a window switch.
For the same reasons I use them on my gas engine.
Troy Simmons
08 F450 4x4
tbsimmons is offline
