So my trannys shot..... - Ford Powerstroke Diesel Forum
Old 03-31-2011, 11:57 AM
Any advice on what to upgrade while I have the replacement on the stand??
Old 03-31-2011, 12:06 PM
How many miles are on it? What happened? Are you towing alot?
Old 03-31-2011, 01:20 PM
64K no towing....slips badly in R and 4 and 5 from what I can tell....It limps every time I try and drive it. Truck was fine, just over 60K so I decided the trans fluid needed a change. Had the Shell Rapid lube flush and fill trans and noticed a diff in the way the truck shifted and the converter locked. Within a few days the truck started slipping in R a little and would limp when I jumped on it. I assumed they put the wrong fluid in it so I went to the Ford place and got the fluid changed today and within about 30 min it was shot....When I went back to shell to get my $$ back @ Shell the manager told me that they didn't even use the Mercon LV Fluid, they added some sort of additive to make the regular Dexron/Mercon work with my truck...What kinda BS is that?? Pretty sure the clutches are burnt
Old 03-31-2011, 01:57 PM
You need to use the LV, I would be pissed at Shell. I would look to upgrade to the suncoast rebuild kit and their tq converter. Let us know if we can help.
Old 03-31-2011, 02:22 PM
They are gonna have to pay for it.....I have a reciept tht says they added an additive and cleaner to the trans and a document from ford saying that lv must be used and any additives or cleaners will damage the trans.....so thats iron clad in court!
Old 03-31-2011, 02:24 PM
SunCoast fo sho!!!!
Old 03-31-2011, 04:00 PM
what is your opinion on the Rebuild kit, vs the full suncoast trans? Full suncoast is out of my price range. I really don't see myself going much further than a stock motor with a 310 race tune. Maybe at some point a slight upgrade on the turbos.
Old 03-31-2011, 07:58 PM
Also interested in the full trans vs the rebuild
Old 03-31-2011, 11:17 PM
What would be a reasonable price to pay a shop to do the Sun Coast rebuild?
Old 04-01-2011, 05:34 AM
I would go and spend the money for a COMPLETE built transmission.... From Suncoast or the Elite unit, direct from the FACTORY.
My Suncoast (which was rebuilt by a Suncoast Dealer) has been apart 3 times, and is in need of a complete rebuild and another torque converter.... in 24,000 miles...... My tires last ~28,000 miles, so I am not beating on my stuff.......
It will cost more initially, but may save BIG money in the short run!
Mike
