Injectors
Can someone tell me the maximum HP upgraded injectors in my truck?
I have the Spartan Tuner license 4 with TCM and stock fuel system. I want to know what HP injectors I can change to without upgrading fuel system or having to reprogram the Tuner. Thanks |
The smallest injectors there making as of now are 60hp form elite...even with those you will need an injection pump upgrade and an airdog or fass lift pump to keep up with the race tunes and injectors.
I seen in your signature that you have a BOV? im assuming its the BD one? How loud is it? does it blow off every time you let the throttle off under high boost? what about when the TC locks? thanks man sorry for the derail..
You will see a VERY small increase in power with 60's with stock fuel. You need to upgrade the fuel system to run bigger injectors.
just found this yesterday.
this is the set up you need man this thing hauls |
Whats almost as impressive as how fast the truck goes, is how well it shifts...
i cant get over how good it runs and shifts. are they a member on the org?
It's the owner of PSN's truck.
You wont get a code for low rail pressure?
