Will 5" exhaust fit? - Ford Powerstroke Diesel Forum
Old 03-28-2011, 11:36 AM
I have a B & W hitch on my truck. My stock exhaust looks horrible hanging down and is getting bent up to boot. Will 5" clear and still not dangle down so low? I have been told they don't go so high over axle so it should but can't get a definate answer. If you have this setup whos kit are you using? Thanks Jason
Old 03-28-2011, 12:40 PM
I have a b and w on mine and mine clears
Old 03-28-2011, 02:30 PM
Thanks I want to get my exhaust purchased as soon as the tax refund gets here. I really want 5" but don't want to have to pay return shipping because it wont fit right.
Old 03-28-2011, 03:48 PM
I have not seen any issues with 5" and GN hitches.
Old 03-28-2011, 03:52 PM
I dont know why the bend in the stock exhaust is so high, with my b&w on my truck going through ditches and rough terrain my exhaust has never hit the axle or my hitch.
Old 03-28-2011, 05:06 PM
Mine has never hit the diff or hitch but has hit the ground several times especially going in and out of fields
Old 03-29-2011, 05:27 AM
i have a 5" exhaust and a B&W gn hitch and no problems.
Old 03-29-2011, 06:41 PM
I just installed a 5" flow pro on my truck with no problems except the clamps that come with it. They are garbage and I stripped the threads on every one. I think they are meant for one time install, which doesn't work so well if you gotta put the stock exhaust back on. I highly recommend you go to a truck shop like for 18 wheelers and get yourself some of band clamps. The ones I got are SS, have 2 bolts, and have a lip in the middle to to clamp down on both sides of the joint nicely. You'll also need a 4" clamp for where the delete pipe connects.
Old 03-29-2011, 07:43 PM
ya and it looks so much better to
