mini maxx max tune with dpf present
Guys,
What is the highest tune you can run safely with the DPF still on the truck using the minimaxx? I just installed mine this morning. Thanks for the help... |
Im currently running the hot tune with my DPF present and it has been fine so far...
You can run any one of the settings you want, but the truck will go into regen more if you run the 120 setting aggressively.
Regen was less frequent with my Black Maxx on the Hot setting. Every other tank instead of once a tank. I didn't run it hard though.
I have not found the regen on/off setting in the programming, how do you know if it's still on? I want to keep mine on for now until I do the DPF delete...
again, thanks for the help... |
i did not know this... i will go look now thoughhoovdog "Regen was less frequent with my Black Maxx on the Hot setting. Every other tank instead of once a tank. I didn't run it hard though. " Same, I havent run mine hard either... except the first time when i was trying it out
I don't know that there is, just asking because "if" there is I haven't found it...
I just looked and i didnt see it.
Guys, running this tune with DPF on the truck without regens will cook your truck.
I selected (DPF Present or Delete) during the download. Did you do the download or a shop do it for you? You can select Menu then settings it will tell you whats programed to the truck. |
