Turbo lag on Spartan? - Ford Powerstroke Diesel Forum
Old 03-20-2011, 06:42 AM
Just ordered my Spartan w/delete tube and AFE, I am wondering about the turbo lag while running with Spartan? Hoping you guy's running it can chime in with some good news.
Old 03-20-2011, 07:03 AM
I think it depends on the tune you run, on mine with the 310 if your running say 30mph and mash the gas there is a lot of turbo lag but when the power comes on hang on your breaking tires loose.
Old 03-20-2011, 07:14 AM
Sure, I know running stock there is a lot of lag, I was hoping that the tuner might get rid of some of it. But even stock, once everything catches up it still sets you back into your seat a little
Old 03-20-2011, 05:45 PM
The turbo lag is greatly reduced on most tunes. I would recommend the 175, 210, and 250 as the quickest spooling tunes. Some of the higher tunes dont spool as quick because they use alot of low end fueling which in excess can cause a slower spooling turbo..the real low tunes like the 40 and 75 spool similar to stock. just by removing the dpf your truck will spool quicker.
Old 03-25-2011, 08:01 PM
when i get out of my 350 7.3l then into my 6.4l all i got to say is wow there is noooo turbo lag! my 7.3l is like a powerband!
Old 03-25-2011, 08:27 PM
When I go between my Trans Am and my truck I notice the lag but down tuning from the 250 to an EGR-friendly 150 makes the 250 feel almost lag free. Huge improvement over stock!
Old 03-25-2011, 09:13 PM
When my truck was stock, it had so much lag it was almost hard/ dangerous to pull out into fast moving traffic... Now with the Spartan 310. Its almost hard/ dangerous to pull out into traffic without putting the truck sideways... Huge difference
Old 03-25-2011, 09:23 PM
Very true. One can also blackout an intersection at will with bigger tunes.
Old 03-27-2011, 03:39 PM
Okay, I got my 250 DPF delete tune, DPF delete, and AFE air filter installed this weekend. WOW! this thing is sweet. I have noticed that at hiway speeds when you get on it, I sure don't feel the turbo lag like it was when it was stock. This thing really gets moving
Old 03-28-2011, 06:26 AM
Keep in mind, no tuner can just turn off turbo lag. The way a tuner get's rid of turbo lag is by dumping in more fuel right off idle. The extra fuel compensates for the fact the turbo hasn't spooled yet and get's the truck moving simply from fuel. The downside is, this is why most diesels emit the puffs or clouds of soot when they launch.
