mini maxx problem?
ok guys i need some help. i installed a mini maxx and dpf delete last night and when i went to start the truck i noticed that the one touch start wasnt working but when you hold the key it starts just fine. so i took the truck out to try out the new tuner and i went to set the cruise control and that isnt working either. my truck is a 10 f350.
I know in my truck the cruise control was working after a couple of cycles, although I didn't try it on my maiden voyage, and obviously my one touch start is MIA. Good luck. |
i spent about an hour last night looking for a blown fuse or something. ill try to cycle the engine a few times and see if it works. thanks for the info.
The one touch start is currently lost while running H&S tuning. We are currently working on an update tuning calibration that will re-enable this "tip start" feature for those that need it. This update is likely to be released in the next month.
Do you have a standard transmission truck? We have had a few cruise control issues with the standard trans trucks, that will also be fixed in the update with the tip start. Hope this answers all your questions. Watch for an update and let us know if you need anything else. Bentley H&S |
the cruise is working now. thanks alot for the help.
Was tip start an option on some trucks? Mine has never had that
