Kem sd card loaded!!
I just got the special SD card for the black maxx and loaded the 345 tune that was very easy to do took about 10 min. then took it for a short drive first impressions it shifts better than the hot damn tune more throttle responce with no let off lag! power wise it did feel stronger but need to drive more to get a better feel for it but it does roll a bit more coal with the 345! now i get to see what the mileage does i think i made a good choice going with KEM! Thanks Muj!
Chris |
Ordered my Monday.....mike said it was shipped same day.....still waiting for it.
How does the install go on these cards. Do you just take out the one in the mini and replace it with the new kem card and then install a tune. Can you switch back to the H&S card when ever you want. Are the kem tunes able to switch on the fly. Appreciate any insight on this i am thinking of getting one of the KEM sd cards.
All you have to do when you get the kem card is remove the h&s card, install the kem card. Then go to update firmware and after that is complete go to install download. You will be able to adjust the tire size and speed limiter, then select the power level (75-345) and wait for it to install. You can reload the h&s files whenever you like by putting their sd card in and following the update steps.
I asked about that. they are not switch on the fly at this time, but they are working on it. no release time line yet.
Got my kem tunes today.......all I have to say is wow...just backing out of the drive way was impressive. Easy to install....definitely can tell a difference between the 345 and the h &s hot tune.
thanks Mike.
I got mine today and loaded that sucker.
![]() Yup!! |
I'm new to the 6.4 I've had mine for about 6 months now. I have the whole dpf delete/minimax/s&b. I'm totally happy with the hot damn tune. That being said. Tell me why yall wanted more power and if yall are worried about the head gaskets with 345 extra hp? I'm not trying to be a smart a$$. I want to really know!!!
The shift on the fly is not out yet but Mike said there will be no extra charge to update! I drove about 60 miles today shifting is better and the pedal has a quick responce on and off of it i even towed a small excavator no problems didnt even feel it back there! I run it to about 80mph and it was pulling hard still going to play with it though! installing was easy swap the Sd and update the firmware then select a tune simply put the H&S card back in and same process!
Chris |
