leaving DOC on...greener right ?
does the DOC hamper a tuner in any way if it is left intact on the exhaust system...i know they do plug up eventually,but if left on and and it is not gunked up,wouldnt it be the greener thing to do? not exactly a tree hugger, but if it cuts NOX emmissions why not?...it is what i'd like to do.i will be ordering the delete stuff pretty soon and if the consensus is go DOC/DPF then thats what i will do.
If you're deleting the DPF not much sense in worring about being green on the DOC. It is alot easier to swap back to stock if you delete both.
ok,but isnt the function for a dpf to capture and burn off soot [which falls to the ground anyway]....i crawled under my truck yesterday and it seems to me just removing the dpf would be alot easier....that youtube video floating around sure makes it look pretty easy and alot less stuff to undo if you leave the cat...BUT if the cat is in anyway restrictive then its gotta go.
It is not easier, its much harder actually. Removing the DPF/Cat is two bolts on the front and a slip joint at the back. Did you not count the bolts on the flange between the DPF/Cat?
yep....saw the bolts...not a problem with air....i went back and wanted to take some pics and saw the thing attached on the DOC pipe about midway..i thought that would have to be unbolted but i see now that it is just a black cannister bolted to the pipe for no apparent reason...dont see any wires attached to it [so what the hell is it anyway?]....guess it just comes out along with the whole pipe...so do you leave the rubber hangers on the truck or take em off with the pipe..the doc/dpf delete pipe doesnt seem to have any hanger attachments.
If you only delete the DPF, you are only getting rid of half the problem. Plus, the DPF/DOC are the furthest thing there is from keeping our trucks "green" IMO
Hell, not much sense in saying Green and Truck in the same breath.
I left my cat in place. Wasn't hard, did it by myself in about 3 hrs
