Mini Maxx Power
Hey everyone. I just installed my mini max into my F-350 6.4L. Got a question. I was suppose to wire the power to the purple wire under the dash. I did that, but it didn't seem to work. So I'm back to using the on and off switch.
I have not done the DPF delete yet. That is later today. But will I need the mini max running when the truck is running? Also, does anyone have any suggestions on how to get the power connected to the ignition? |
Did your purple wire have power with the key turned on? I checked my purple before I spliced into it and it was hot with the key on. I then spliced into it. The first time I turned the truck on the Minimaxx didn't power up. Just had to flip the switch on the OBDII plug. Then it was in the right position to turn on and off with the key. No problems at all so far.
I turned on the key, but had to turn on the OBII to get it to come on. But when I turned off the truck, the mini max didn't turn off. That is why I didn't leave it. Also, I used those terminated wires in the bundle under the dash. Are those the right ones?
Ya its the bundle of wires that are by the ebrake release handle. The wires all have the black protective ends on them. If you have a voltmeter or test light check that purple that you spliced to see if its hot with the key on and not with the key off. Its probably something minor to do with the switch. The OBDII is always on but having the switch in the right position will allow the Minimaxx to be turned on and off through the power wire.
I installed the dpf delete and mini maxx like this:
Install the mini maxx dont worry about the purple wire yet. Load the dpf installed tune. Start the motor to assure alls well, shut the engine off. Next, drop the dpf/doc and install your new delete system. Turn the key to the run position, after the mini boots, use the menu to find the change settings , select dpf removed tuning , the new mode of tunes will install. Start the engine and play with the tuner to check out all the stuff, defuel settings ect. Shut the engine off, and splice the power wire into the solid purple wire in the bundle. Note, there are three purple wires in the bundle two of them have a trace stripe on them, only one is solid purple, look closely and select and splice into the solid one. Make sure the mini's obd11 adapter switch is in the always on position, now the mini will turn on and off with the ignition. Theres quite a few ways to succesfully do the whole job, my discription definitely works. Have fun |
Thanks for the help guys, I'm getting ready to change out the pipes now.
I'll let you know how it goes. |
We'll be looking for your success reply!! But if you run into anything confusing, even though it may seem dumb, sound off on it. The whole job is not that easy, everyone whose dpf deleted knows that. Few at home mechanics complete without a little blood shed haha.
It's not that bad, once you get past the fear of tearing something up. I originally had a spartan and the biggest concern with it was not breaking the sensors in the exhaust. Now that those don't have to be removed it is a pretty straight forward job. Swapping out the intake can end up being the most time consuming part.
Im about to order all my stuff. How hard is it to change from the DPF on tunes to DPF off tunes?
