MBRP IC Pipe - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-18-2011, 06:44 PM Thread Starter
08FX4RBP's Avatar
Angry MBRP IC Pipe
Just got my MBRP IC pipe today.........After trimming and fitting, it clears the radiator support no problem.......just nothing else.....the mounting tab can not be used to mount it, its no where close...off a good half inch. If you do line it up, the bends are off so far you just look at it and laugh. The closest i can come to make it work is not to use the mounting tab at all, but it still because of the bends sits sandwiched between the side of the radiator and the body. No wiggle room at all, my only worry with this is if it will rub through and or break the side core of the radiator? Just thought this would fit a little better than it does.
If you have any ideas shoot them my way...probably be looking at buying a different one also.
2008 F250 FX4 CC, Short Bed, Red/Chrome
AFE CAI,MBRP Cool Duals,DPF Delete,MBRP 3 inch Cold Side IC Pipe, 37's SS M16's,ReadyLift 2.5/2.0 SST Kit,Rancho RS9000 Adjustable Shocks,Fox Racing Dual Steering Stabilizer,Recon Smoked LED Tails,3rd Brake,Mirror Turn Signals,LED Dome,Smoked Cab Lights
08FX4RBP is offline
post #2 of 17 Old 02-18-2011, 07:04 PM
cbenn's Avatar
Quoted: 2 Post(s)
Call Aaron (Rudy's) he will get you set up with what he carries, I installed one and there was no grinding, snug fit but put 1/8" rubber in a couple places and go to go.
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #3 of 17 Old 02-18-2011, 07:10 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
What if you took a plate and extened the mounting tab to make it fit. I would probably call MBRP up tho and ask them WTF.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #4 of 17 Old 02-18-2011, 07:16 PM Thread Starter
08FX4RBP's Avatar
extending the mounting plate wont do anything. To make it fit in anyway i will have to ding the pipe.
08FX4RBP is offline
post #5 of 17 Old 02-18-2011, 07:21 PM
Quoted: 10 Post(s)
Oh alright, I still vote to call MBRP, it should fit fine. Maybe they bent it wrong
Allen
post #6 of 17 Old 02-19-2011, 07:15 AM
I had the same exact problem plus the bends being off and putting the boots in a bind. I ended up buying the pipe from Aaron at Rudy's and couldn't be happier. I sold the MBRP fairly cheap to a member on here, maybe he can modify it to work but I was too frustrated to mess with it.
I have a thread on here about it if your interested.
rlpzzz is offline
post #7 of 17 Old 02-19-2011, 12:30 PM
DSTRBD's Avatar
If you bought it from us, please give us a call and we will get it sorted out with MBRP. We work with them every day and they will take care of you.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #8 of 17 Old 02-20-2011, 10:52 AM Thread Starter
08FX4RBP's Avatar
Yeah i did, i will contact you monday on it.
Thanks again for the help.
08FX4RBP is offline
post #9 of 17 Old 02-21-2011, 08:01 AM
I had to eliminate the tube's mounting tab intended to be tighten with one of the radiator’s support screws. It didn't align at all and after the work done (disassembly and radiators’ bridge grinding) ended by grinding the welds to eliminate the tab. Really, it doesn't have any space to move, I left the exact space for it. Except for that, it looks great, fits well, and works perfectly. Nothing better than a completely round pipe (the most cross sectional area per perimeter compared with any other shape). I posted some photos in the following thread answering a request.
Mbrp downpipe?
CaribePickup is offline
post #10 of 17 Old 02-21-2011, 01:39 PM
Jesse@MBRP's Avatar
Just wondering if anyone had touched base with our Customer Service Department? My apologies on this experience and please allow us to make it right. Just give us a ring at 888-636-7223.
Jesse Rohr - MBRP Performance Exhaust
email -
Become an MBRP fan on Facebook
Jesse@MBRP is offline
