Hollowing out CAT/DPF - Ford Powerstroke Diesel Forum
Old 02-15-2011, 07:17 AM
Wondering if anyone has hollowed out their CAT and DPF instead of using a delete pipe?
If yes, do you have any advice for someone who wants to try it?
What did you use?
Old 02-15-2011, 07:23 AM
I did it on my 03. I just used a piece of steel rod and a hammer. It's pretty slow going at first, just making puncture holes. You'll think you arent getting anywhere, but after several of those, that mess starts to break up pretty easily.
Old 02-15-2011, 09:44 AM
Its not real cost effective to do this, they are very spendy to replace if you need to. Why not just get a kit to replace them instead?
Old 02-15-2011, 10:14 AM
What Nate said I agree,
Old 02-15-2011, 10:46 AM
Thought it would be good to have the look of stock so if Barney started looking into it, he might not catch on.
If warrantee is out, I don't see why you'd replace it unless Big Brother gets involved. We don't have inspections yet here where I live.
P.S. How many miles does warranty cover?
Old 02-15-2011, 12:44 PM
100,000 motor & drivetrain
Old 02-15-2011, 04:29 PM
I bought a used dpf for 400 and hollowed it out. I used a hammer drill and a long one inch bit. Wear a mask, it is dusty and has some kind on insulation in there too.
Old 02-15-2011, 05:33 PM
I just did this too for the same reason . Bought a used one and used an air hammer with a long chisel in it . It went pretty quick,but def. wear a mask. The cat was easy ,the dpf was a little tougher but not bad.
Old 02-15-2011, 06:54 PM
Feedback Score: 3 reviews
are you guys that did this mod, running a tuner?
Old 02-16-2011, 04:23 AM
They would have to use a CAT/DPF delete tuner to stop the regeneration process.
