Going to dyno the 6.4 Saturday - Ford Powerstroke Diesel Forum
Old 02-07-2011, 09:25 PM
Ok guys, I'm going to dyno my 6.4 at Relentless Diesel this Saturday and I need some advice. I've never ran on a dyno with a diesel or an automatic, so how should I do it? I'm running the spartan 310 tune. I've heard to get it up to 65 so it wont down shift and then get on it. Does this sound right? I also heard not to worry about building boost. Any advice is appreciated.
Old 02-07-2011, 09:32 PM
65-70 MPH is good for the 310 tune. At that speed, it shouldn't downshift. If it does downshift due to load, bump the speed up higher until it doesn't downshift anymore. Just roll in to the throttle. You should see pretty close to the same amount of boost you do on the street.
Old 02-07-2011, 10:44 PM
see ya there, except ill be dynoing just the 250 tune
Old 02-09-2011, 12:25 PM
ok awesome. thanks for the help. by roll into the throttle do you mean ease in to it? or hammer it?
awesome man. i'll see you there! i'll be there about nine so i can get my truck run early. what time are you lookin at being there?
Old 02-09-2011, 04:51 PM
you shouldnt be driving the truck, the shop should. But the above advice is good if you do, and BTW do not hit your brakes!!
Old 02-09-2011, 07:31 PM
keep us posted
Old 02-09-2011, 08:14 PM
I'm meeting all the guys from diesels on the brazos at the sams parking lot at 8 then we gonna leave, we should be there at about the same time
Old 02-09-2011, 08:18 PM
We Might have to, I'm not sure if the dyno is a load dyno or not, the guys that are dynoing their trucks might have to hold the brake to build boost, if it's a load dyno then that shouldn't be necessary, correct me if I'm wrong but that is what I was told
Old 02-09-2011, 09:44 PM
Load dyno or not, you won't need to hold the brakes to load the turbo's on your truck up. You don't have a big single or a big set of compounds. These are fast spooling stock turbo's. If you have to hold the brakes to spool the turbo's, you shouldn't have your truck on the dyno in the first place.
Old 02-10-2011, 09:20 AM
Damn, forgot all about the dyno day up there. I will be at the Supercross event at Reliant in the Edge/MBRP booth, otherwise I would be there. I am very interested to see the numbers from the event.
