Turn off the egr? - Ford Powerstroke Diesel Forum
Old 02-05-2011, 09:12 AM
Turn off the egr?
I just heard something that made me wonder what the difference is between a tune the shuts off the EGR and a tune that Cycles the egr? Anybody know anything about that?
Old 02-05-2011, 09:30 AM
you want to cycle the egr unless you never plan on going back to stock. if shut off completely for more then a few thousand miles it will get stuck. so if you go back to stock your pickup wont really run with a stuck egr valve
Old 02-05-2011, 12:45 PM
So, what tuners and tunes shut off the egr?
Old 02-05-2011, 01:10 PM
I know that my H&S Mini Maxx does it . kinda sounds like a little bit of a rattle when i first start it up . don't know about Spartan though .
Old 02-05-2011, 02:06 PM
Got Mike at KEM to make a tune that will cycle the EGR at idle.
Old 02-05-2011, 02:16 PM
So it it a bad or good thing. I would think if anyone needed to go back to stock this could be a problem? If it does get stuck.
Old 02-05-2011, 03:33 PM
The Spartan system has tunes that cycle the EGR.
Old 02-06-2011, 07:35 AM
Is the tune compromised in any way by cycling rather than just turning it off?
Old 02-06-2011, 08:15 AM
The EGR only cycles at idle, so that the system doesn't get clogged-up and become totally non-functional, in case you need to return the truck to stock for warranty repair.
The EGR does not operate when you are running down the road.
The "tune" is not compromised in any way and the "cycling" at idle is actually a function of the tune.
Old 02-06-2011, 08:21 AM
On what tunes does it cycle on at idle?
