Exhaust / Tuner question - Ford Powerstroke Diesel Forum
Old 02-04-2011, 01:46 PM
So if you replace your exhaust from the down pipe back, you will need to get the pyro kit? I am looking at getting the H&S Black Maxx, along with a 4 or 5 in stainless exhaust. Just want to make sure I order everything I need.
Thanks for any help
2008 6.4
Old 02-04-2011, 01:49 PM
The Silent Service
Not unless you run the pyrometer into the exhaust, but thats not a good way to run it anyway. It should be routed to your exhaust manifold, pre-turbo, for the most accurate temps. You should be fine with the H&S, Pyro, and your exhaust choice.
Old 02-04-2011, 01:59 PM
I talked to H&S, they said if you replace your exhaust it removes the egt sensor that the factory puts in, therefore you will have to drill and tap into your exhaust manafold. I was under the impression that this is where ford had origionally put the factory pyro. Why would they put it on the exhaust pipe its self? I guess I will just have to pay the extra for the pyro kit for the black maxx.
Old 02-04-2011, 02:08 PM
No need for pyro. It reads the egts from the obdII ports itself once black maxx is installed.
Old 02-04-2011, 02:51 PM
Thanks, Just ordered a mini maxx with 4" afe exhaust. Cant wait, should bo installed by thursday
Old 02-10-2011, 09:44 AM
The 6.4L reads the factory pre-turbo pyro so there is no need to drill/tap anything.
