WHY? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-01-2011, 01:38 PM Thread Starter
WHY?
can somebody tell me why this happened? truck was only driven for about 10min. at normal speeds 30/55 . pulled in driveway and seen that. its about 30deg where im at.
Name:	defuel coolant.jpg
jato1229 is offline
post #2 of 10 Old 02-01-2011, 01:48 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Is your coolant low?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 10 Old 02-01-2011, 01:51 PM Thread Starter
no. anybody else?
jato1229 is offline
post #4 of 10 Old 02-01-2011, 01:54 PM
Every now and then my mini will buy out and give me close to same reading.
The funny thing is that, that's not hot coolant, thats very cold coolant.
Don't know why it happens. You can try H&Ss website. They have forums that moderators read.
*SOLD*2008 F250 6.4: H&S Mini w/ Bully dog mount, Flo-Pro DPF/CAT delete, AFE stage 2, Viper 5901 Remote start.
2012 F250 6.7: S&B CAI, H&S Mini Maxx, 5" MBRP straight exhaust, Firestone airbags.
Grunnsetning is offline
post #5 of 10 Old 02-01-2011, 01:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
How cold is it outside?
Most companies have a parameter that defuels until the engine oil and coolant are warm
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 10 Old 02-01-2011, 01:59 PM
woww thats not right, must be a bug..call H&S asap...
Vettester is offline
post #7 of 10 Old 02-01-2011, 02:53 PM
We have seen this one a few times. There is a communication error between the truck and the Mini Maxx at some point during initialization. This causes the coolant reading on the Mini Maxx to peg at one end of the temperature monitoring spectrum. It will also cause a "hot coolant" defuel due to the way we do some of the calculations inside the Mini Maxx itself. We are looking into a solution for this, but at this point have no ETA on availability. For now, just unplug the unit and plug it back in, and it will reset it. It should only happen on very rare occasions when the variables are just right to cause it.
H&S Tech is offline
post #8 of 10 Old 02-01-2011, 03:43 PM
jberzerker's Avatar
I have had this happen to my truck a couple times a while back and I just cycled the power on the minimax and its fine.
jberzerker is offline
post #9 of 10 Old 02-01-2011, 05:09 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
-40 ECT is full v-ref and would indicate an open circuit somewhere in the ect wires...........if you had an actual scantool
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 10 Old 02-02-2011, 05:07 AM
That same thing has happened to me twice. If you have the Mini hard wired to the truck just toggle the switch that is on the OBD II port reader and it will reset itself. Once the mini resets drvie it as you normally would.
2002 4X4 crew cab. DP 140, 120, 80 tow. AFE stage II, 4" SS magnaflow,
H2E, Tapercore, Ride Rites,, Grover air horn and onboard air, Terminator 2. BTS Trany [B]SOLD[B]
2008 FX4 crew cab F350. Edge Insight (for now)
dmdiesel is offline
