airdog II 165 install, finish - Ford Powerstroke Diesel Forum
post #1 of 35 Old 01-31-2011, 03:08 PM Thread Starter
This is a continuation of my airdog II dumptruck method install airdog II install dump truck method phase 1 .
The installation goes something like this:
Remove both connections at the trucks fuel basket Cap, connect the dogs 3/8" fuel return and the 1/2" fuel suction line to the vacated male quick connectors on the tank cap. Reconnect the two fuel filler tube lines and lower the truck.
Theres two connection leads for the airdog , one is for the power , the other is for the optional fuel pressure guage.
This shows the 3/8" return line back to the Fuel basket, and the pressure line running to the engine .
This is obvious but please Note: The dogs "Special Tee" picks up the 3/8" return line from the engine , the two remaining 3/8" ines must be returned to the tank in one of several ways. (recommend) Splice into the airdog return line with two 3/8" T fittings. Or weld two fuel bungs into the trucks filler tube. Or drill and fit the Fuel Basket Cap with two 3'8" fittings, this is the hardest if your using the dumptruck method, because you must remove the bed or drop the fuel tank. So choose your poison .
This is how the electrical goes: Tie down the relay and 20amp fuse securely, I did like this.
The line running up into the engine bay is + and - wires for the Batt.
Hook the airdog II "Red" 12v ign. switchable wire into the electrical system Like this:
Disconnect the white connection from the OE pump socket, seperate the "purple and White" wire and cut it. Then run the dogs, "RED" wire, to the "Purple and white" wire. Cut the RED wire below the fuse tap , see the last pic, and splice it into the Purple and white wire. The Black ground wire isnt needed.
This is the fuse tap end of the "RED" wire. It would be used to connect into the trucks fuse Box. But, the ford 6.4l is best connected at the oe fuel pump. location.
Prime and bleed the system like this:
(recomend) If you have the on engine Fuel filter housing Cap off then put towels around the housing then cycle the key to the run position for 4-5 seconds then off, repeate this until cleaned fuel gushes. Or loosen the fuel line connection at the engine fitting and cycle the ignition run position until the fuel is running out clean.
Thats about it, not real difficult if you know for sure what your doing, I was kind of vague about the "RED" wire and had to dope it out.
On another note, the airdog II 165 instruction manual sucks, Its not complete and neither is the Kit itself. Its missing the entire return to tank hardware. After figuring that out, I went to the hardware store for 3/8" fuel line , The two 3/8" T's and all the clamps.
The good part is, My trucks fuel injectors are loving all the super clean diesel fuel they are recieving. I believe the ad II 165 is another critical mod, Air in the fuel at the injectors is a No-No in a big way. I consider it cheap insurance for the overall life and reliability of the engine .
If your a back yard mechanic and go for the at home, on the ground way to install this kit, be sure to get the "quick disconnect tools" Be firm but dont strong arm, The lines can be a Pita to disconnect. Have fun its way worth it
Kudos Nate the excellent rep. at PTP who sells the Airdog's
Vettester is offline
post #2 of 35 Old 01-31-2011, 05:44 PM
Thanks for the writeup and pictures. I plan on doing an Airdog when I get a titan fuel tank here is a few months.
Antonm is offline
post #3 of 35 Old 01-31-2011, 07:46 PM
Nice write up and thanks for info. I would like to do this mod one day.
2008 F-350 6.4 Power Stroke 4X4
CC LWB SRW Auto 3.73's
BigIslandBoy is offline
post #4 of 35 Old 02-01-2011, 07:45 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
nice write up. So do you take off the old water seperator and water filter and mount the airdog where it was?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 35 Old 02-01-2011, 07:57 AM
DSTRBD's Avatar
Thats an excellent writeup man, thanks for sharing. Glad to hear you are liking the Airdog II!
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #6 of 35 Old 02-01-2011, 07:59 AM Thread Starter
No, it mounts in the more open area south towards the tank, on the other side of the crossmember. Find your spot in that area. The oem pump does not need to be removed , I just disabled and left mine right where it was. Be sure to pull both leads Off the oe pump to assure there is No power to the old pump.
TC
post #7 of 35 Old 02-01-2011, 09:50 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
TC
good deal! Thanks
08 F350 cc/sb 4X4
post #8 of 35 Old 02-22-2011, 05:01 AM
Vettester
Many thanks for sharing your experience and knowledge with us.
I have some questions: The OE filter at the motor should be still used? If yes, that filter could be bought alone (As up to I know the OE fuel filters comes in a set)? In addition, did you notice the better performance claimed by Pureflow (Airdog) relative to the removal of air from the fuel?
CaribePickup is offline
post #9 of 35 Old 02-22-2011, 07:55 AM Thread Starter
Originally Posted by CaribePickup View Post
Vettester
Thanks Caribe, Yes the filter at the motor is still used, so the "filter set" becomes a drawback. I havent found the top filter as a single yet, but will continue to look. Dont want unusable filters piling up in the garage
I think the only very noticable thing regarding the power would be the fuel supply at High boost. Example , getting into the truck for an all out romp with the,Hot damn or KEM 345 tune, during a 10-12 second run. Theres zero chance the injectors would starve due to insufficient supply from the airdog II system to The HP pump. Its doubtful the OE pump would suffice.
But for us daily drivers ,Whats most important is the assurance of much less or no airated fuel at the inj. nozzle. Next is cleaner and cooler fuel at the inj. nozzle. All making for improved effeciency. Thats what I was looking for with the Dog 165.
PS It would be REAL cool if Pureflow would sell the OE filter along with the spin ons at a reasonable price!!
post #10 of 35 Old 09-05-2011, 09:28 PM
Haulin
I have an 08 F-350 and I want to install one of the Air dog systems, what is the difference between them? Also is one system easier to install than the other?
BigBlue_08 is offline
