Innovative tune for 6.4 Help!
Anyybody that has the innovative tune for 6.4 please help me out. This might sound like a dumb question but whats the diff. between the AXLE RATIO setting and the TIRE REVS/MILE setting? Which one would be better?? Thanks!
Axle ratio is your gear size (ex.3.73) and tire rev is the amount of revolutions per mile your tire makes. It is found on the tire manufacturers spec sheet and is very accurate if you can find the #.
Oh alright perfect, thanks alot!
Don't even touch the axle ratio figure unless you have changed your gears. If you don't answer this, the computer will use your stock value. Same goes for tires - there is already a stock value in there. You only need to answer these questions if you are changing something. I need to change my tire size but I traded my SCT Livewire in for the newer and greater SCT "TSX" - unfortunately, it can't do that! Duh?
