High idle after putting tuner on - Ford Powerstroke Diesel Forum
Old 01-29-2011, 11:02 AM
I just helped a friend install the AFE delete pipes and an MBRP dpf back system on his truck. We also installed an SCT Livewire Extreme. Now the truck idles at 1000 rpm. He had the tuner on before we installed the delete pipes and it ran just fine. The only thing we changed was we told the tuner the dpf was deleted. It also has the wrench light on.
Sorry for the long post. Thanks for any help.
Old 01-29-2011, 04:28 PM
I had the same issue with mine it ended up being one of the dpf sensors wasnt connected ! make shure they are all connected and ur idle will return to normal
Old 01-29-2011, 04:31 PM
I had wrench light turn on on mine also since i had just installed the tune and didnt have the truck go through the relearn process and did a 4hi launch ! reinsalled tune and let truck get used to the tune and it hasnt turned on since
Old 01-29-2011, 06:03 PM
Thanks for the help. I started wondering today if that was the problem. We didn't install all of the sensors because the brass part of the pressure sensor stripped out while removing it. He's gonna go to the dealership and get a new one.
Old 01-30-2011, 06:22 AM
I had same problem !! lube it up with wd40 real good get a set of vise grips and get em on there as tight as u can and it should come loose !!
