minimax relearn.
guys i know this has been talked about before, however relearning the tranny on the minimax how long did it take. it tried what the manual says, should it work as soon as im done? kinda worried about driving the truck normal, thinking the tranny is gonna fall-out.any info will help.
The tranny will relearn with your driving habits. All the 0-60 and 0-80 steps just helps make it relearn quicker.
I couldnt do the 0-80 relearn on mine. Too icy out where im at
yea alot of snow here to. how long b4 it relearns. once it does, will it ever come back.
Mine has the same problem. Under partial acceleration on the hot setting, the tranny locks and unlocks violently and the check engine light comes on, and tranny won't shift out of 4th gear. If I stop and shut off the motor, everything goes back to normal. Mini has been on for about 1500 miles.
Really suprised to hear y'all are having those kind of problems. Have you tried calling h&s? Not rubbing it in, but my tranny smoothed out within a couple of days. You really have to do the relearn immediately after installing the tune. Try puttingy the truck back to stock on the tuner......drive it a couple of days and see if the shifting smooths out and then reload the tune. Good luck
can u put the truck back to stock, w/out the pipes. cat,muffler and dpf?
You could leave the tuner on it, just put it back to no power setting.
like the lowest hp setting? also did the learn prosess yesterday, well kinda due to the snow/ice/wet roads. seems today it got much better then it was. should i go back and start over or give it a little more time. mayb even do the learn prosess again?
Mine will shift good in wild and mild, but revs, locks, revs and slams bad in hot tune-unless under WOT. Its not the tranny, I've had this truck since new and has always shifted great. 67K miles.
