why can i make more boost at 3/4 throttle than at full? - Ford Powerstroke Diesel Forum
Old 01-28-2011, 09:35 AM
i was just curious why i can make more boost at 3/4 throttle than at full throttle with either my kem 345 or my h&s hot tune?
Old 01-28-2011, 09:45 AM
I am going to take a guess and say that 3/4 throttle is not enough to down shift so its under more strain.
Old 01-28-2011, 09:54 AM
i agree ^^^ but i'm sure someone with more expertise will let us kno
Old 01-28-2011, 12:49 PM
I've always thought that with some of these tuners that "full throttle" could be short of your pedal hitting the floor and that is why some think they're boosting more before "full throttle". Basically that full throttle is before the floor and anything more is wasted or not read by the computer. May sound stupid, just a thought...
Old 01-28-2011, 01:27 PM
Old 01-30-2011, 09:47 PM
Send a message via AIM to tonypagnano
boost occurs under load, and at 3/4 throttle your rpms are going to be lower than at full throttle putting a larger load on the engine. Hope this makes sense
Old 01-31-2011, 02:56 AM
Not completely sure but I think it is because of the EGR programing....
Old 01-31-2011, 09:55 AM
Try full throttle at about 70 MPH. You should see more boost then.
3/4 throttle at a lower speed is going to keep the torque converter locked. With a locked torque converter, your going to see more boost. WOT at a lower speed is going to un-lock the torque converter and allow the motor to rev higher, which will give you less boost.
