occasional throttle interruption with h&s hot setting - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-25-2011, 07:43 AM Thread Starter
i have a minimaxx with the h&s hot setting installed and sometimes if i go full throttle from a stop, around 2nd or 3rd gear it will act like traction control or something, the truck will completely get off throttle for a second then get back on it. its not defueling, and no check engine lights
505powerstroke is offline
post #2 of 14 Old 01-25-2011, 07:51 AM
Vettester is offline
post #3 of 14 Old 01-25-2011, 11:41 AM
Served Our Country!
HighOn20s's Avatar
Feedback Score: 3 reviews
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
Have you called H&S?
USMC 96-00/0311
If you don't stand behind our troops, please feel free to stand in front of them.
2008 F250 Supercrew, Custom 14'' 4-link, F.O.A 2.5 Coil overs, 40/15.5R22 Toyo MTs on Hostile 22x14 Wheels, Yukon Lockers/4.56 gears,
PSC Hydro kit, H&S Mini Maxx with KEM 345 Tune, S&B CAI, TurboSmart BOV, No Limit Fab IC, EGR Delete w/ CSP, MBRP 5' exhaust, AirDog II, TransferFlow Tank, Rigid Industries Lightning!.
HighOn20s is offline
post #4 of 14 Old 01-25-2011, 05:37 PM
What is your Pyro defuel set at. The first couple WOT runs on hot defueled when I had the Pyro defuel set to 1450. I raised it to 1600 and it won't defuel on 0-80 runs now. The defuel happens fast and if your not watching your minimaxx closely you won't catch it. It will bounce between the hot setting and one of the lower settings until you let off. If this doesn't work email Casey or Bently. I've never had to wait more than a few hours for a response. Their customer service is very good.
Jasin
2002 4X4 crew cab. DP 140, 120, 80 tow. AFE stage II, 4" SS magnaflow,
H2E, Tapercore, Ride Rites,, Grover air horn and onboard air, Terminator 2. BTS Trany [B]SOLD[B]
2008 FX4 crew cab F350. Edge Insight (for now)
dmdiesel is offline
post #5 of 14 Old 01-25-2011, 06:24 PM
same with me.
jato1229 is offline
post #6 of 14 Old 01-25-2011, 06:31 PM
Ipkyss's Avatar
If it is happening right at a shift... If the transmission does not shift right or quick enough, it will defuel for a second to shift. Its as quick as turning a light on and off. My truck has done it a few times when I didn't let it learn a big tune long enough before running it full throttle.
2008 F-250 6.4 Auto, CC,SB,FX4, 2" lift, 285/65/20, Spartan tuning, Elite studs, Elite egr delete/wastegate, Elite push rods, Spearco Intercooler, cold side pipe,CFM, 4"down pipe,Custom 5" DP back exhuast 543HP/1231 ft-lbs
Everything from Sean at Street diesel performance
Ipkyss is offline
post #7 of 14 Old 01-25-2011, 06:37 PM
SOUNDS THE SAME, JUST INSTALLED TODAY(TUESDAY) WHATS THE FIX?
jato1229 is offline
post #8 of 14 Old 01-26-2011, 06:31 AM Thread Starter
i think it may be what others are saying about not letting the tranny relearn enough, i had just swapped my kem 345 for the hot and didnt really let it relearn. even so i will call h&s in the next day or 2
post #9 of 14 Old 01-26-2011, 10:00 AM
y did u get rid of the kem 345?
jato1229 is offline
post #10 of 14 Old 01-26-2011, 07:20 PM
fenner408's Avatar
My truck does the same thing. It will mess up shifting 3 to 4 when 75%- 100% throttle, but only when starting at a rolling start. I am running the Hot Damn tune, and have my EGT defuel turned off. It does not say its defueling when this happens. Maybe we can get some insight from Bentley or Casey on this.
2010 F-250 CCSB, Black Maxx w/ MCC, MPD S472, AFE Stage 2, Dirty Diesel CAC
Dirty Diesel EGR Delete, 5" Exhaust, 4" Down Pipe, Daystar Leveling Kit
20x12 Fuel Hostages, 35/12.5/20 MTZs, Custom Traction Bars, Custom Axle Blocks, Custom ALAs.
703HP-1324LB/FT
fenner408 is offline
