New Tuner?
I'm going to buy a mini maxx w/delete. Do I need a after market air filter or can I use the stock one. Cause when I tuned my 6.0(SCT), every body was saying that the best filter is the stock one. So I'm not sure on what to do, I would realy like to add it later down the road but dont want to starve the truck for air. What's yall's thoughts on this. Thanks
If you run the lower tunes you will be fine. The Race Tunes you will suck the filter minder in. Also if towing heavy you might on the lower tunes.
I dont have one but have been fine, only pull hte filter minder in about 50%, but I run the Innovative Tow Tune 95% of the time. Without the trailer the filter minder doesnt move. |
What about the hot damm tune for the minni max?
i would def put a cold air intake system on it... this intake system is not like the 6.0L intake.... if not i would just run the lower tunes...
PM me if you need any prices.. i can get you a great deal on the H&S, delete pipe and intake if your interested -Raul |
You could also just do a high flow drop in air filter to the factory box. Let us know if we can help.
You will have to have atleast a high flow drop in filter if you want to run the H&S on the highest tune. Otherwise it will suck in the filter minder. High flow drop in filter is also about the same price as a Ford replacement filter.
So, if I want to run the hot damm on the minni max to get the best fuel milage, I need a high flow filter. Do those high flow filters filter that good? I've been told more air flow, more dirt!
Yes, at the very least, if you dont want a check engine light. A full intake would be much better though.
To get the best fuel mileage, yes. They filter 99.9%. I would recommend going with the pro guard 7 media for the filter.
