clutch upgrade
I have a 08 f350 with dpf delete 4" exhaust and s&b intake sct livewire with no custom tunes just the pre loads the most they say they ad is 180hp does anyone have this clutch and will it hold up Item #: 1950-64FEK
South Bend Clutch Ford 6.4L Powerstroke Diesel ZF6 Clutch 550HP 2008+ Ford 6.4L Twin Turbo Powerstroke Diesel ZF-6 Speed Manual Transmission 1950-64FEK 550 hp, 1100 ft. lbs. of torque FE - 8 Feramic buttons per side of clutch disc |
I had a Con OFE on my Dodge and loved it. Most with that kind of holding power will chatter your teeth out when you let out but the South Bend was close to stock.
im running that clutch in my dually. definitely will hold (250+ hp) but extremely harsh let off. doesn't like to slip on take off. backing a trailer can be tricky, i usually put it in low range with out hubs locked.
I put the 650hp southbend on mine.
Been checking on this myself. So far this one looks good. Smooth engagement.
South Bend Street Dual Disk 3600 Plate Load 650-750HP from South Bend Clutch |
FWIW I have a SB in my obs and I love it.
does anyone recomend the 550hp single disc clutch and what is the price on the 650hp dual disc clutch
Feel free to give us a call for pricing on the various clutches, we are authorized Southbend clutch dealers. Thanks
