Airdog165 on a reg. Cab - Ford Powerstroke Diesel Forum
Old 01-06-2011, 03:16 PM
Anyone do this? There is not enough room between transfer case and fuel tank like on an extended cab. And I haven't got to the wiring yet but where is the pressure sensor? And it says it's factory set at 10 psi. Is this enough for the 310 tune? And will my dash daq tell the psi?
Old 01-06-2011, 03:19 PM
Mount it on the outside of the frame rail. 10 psi is plenty. I would actually lower it some to prevent codes. You can't monitor fuel pressure with the DashDAQ, only fuel rail pressure.
Old 01-06-2011, 03:34 PM
Thanks! So what are the other wires that I took off the pump for? Will this throw codes left unhooked? Would you put in a manual gauge somewhere? there is an 1/8 pipe plug on the engine side but because of the big fitting there is no way for this port to be used. There is one on the top for something . 8psi maybe?
