Check Engine Light and Codes - Need advise
Hi
This is for my buddies truck that has the Spartan 250 loaded up. It is an 08 350 with about 60,000 km on it. He has a check engine light coming on every so often. I used the dashdaq to scan for codes and this is what came up... P006B - Map - Exahaust pressure P1000 - OBD Sys Rediness P2263 - Turbo Boost Sys Performance P2563 - Turbo Boost Control Sensor B1318 - Battery low voltage Should he go back to stock and take it to the dealer? THanks for your input. |
The P2263, P2563, and P006B are either MAP sensor or EBP sensor related.
So could the EBP sensor have been damaged during the exhaust changover?
The EBP sensor is not in the exhaust behind the turbo....unless he did an EGR delete w/wastegate, he would not have messed with the EBP sensor.
So he should go back to stock and back to dealer.
Thanks Jeff |
