Help? which Traction Bars - Ford Powerstroke Diesel Forum
Old 01-04-2011, 07:17 PM
Which traction/ladder bars are you guys using?
I have seen the pro comp ones for around 450 bucks and then rize makes a slick set for 1000. Fab tech has a set but don't care for the look, they are also around 1000. why are pro comps so cheap?
I have a 6in fab tech and need a set to clean up the shifting for the back max.
Old 01-04-2011, 07:21 PM
They are not designed properly in my opinion. I can't see how the truck will ride good and the suspension will lose it's full range of travel. One Up Offroad look like the way to go.
Old 01-04-2011, 07:23 PM
One Up Offroad OUO Parts on Trucks
Old 01-04-2011, 08:58 PM
OUO or Precision Metal Fab!
Old 01-04-2011, 09:17 PM
i would go with the PMF traction block setup....
Old 01-05-2011, 02:50 AM
Fabricated Unitized Floating Traction Block - Precision Metal Fab
Old 01-05-2011, 03:48 AM
I have the Fabtech 6" lift and went with OUO with 5" blocks. You get what you pay for!
OUO with blocks.
Old 01-05-2011, 05:19 AM
Is OUO the same company hs Truck Toyz? Truck toz name comes up on the OUO wesite
thanks for the help ,the ones from OUO look like the ones I will go with
Old 01-05-2011, 06:02 AM
Are traction bars only for lifted trucks? Mines not but would this help with the hard Spartan shifts? And it's a reg. Cab an I've not found any yet for it.
Not the same company. One up Offroad is in Oregon. Truck Toyz is their main distributor.
