bm/mm/dd how many parameters at a time? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-02-2011, 09:24 AM Thread Starter
suban's Avatar
how many parameters can the blackmax, minimax, and spartan dashdaq monitor at one time. also can they all monitor these parameters?
egt
engine oil psi
engine oil temp
engine water temp
trans temp
torque converter
i would like to run all six but there might not be enough room. i am about to pull the trigger so i want to get my ducks in a row. i read the showdown thread and searched like crazy but couldnt come up with an answer
thanks for any help offered
2001 f250 extcab lariat 7.3
2003 f550 cab&chassis 6.0
2008 f350 crewcab drw 6.4
2010 f250 crewcab kr 6.4
suban is offline
post #2 of 8 Old 01-02-2011, 10:27 AM
Ipkyss's Avatar
I monitor seven on the Dash Daq and I think you can do up to 12. Not sure about oil psi.
2008 F-250 6.4 Auto, CC,SB,FX4, 2" lift, 285/65/20, Spartan tuning, Elite studs, Elite egr delete/wastegate, Elite push rods, Spearco Intercooler, cold side pipe,CFM, 4"down pipe,Custom 5" DP back exhuast 543HP/1231 ft-lbs
Everything from Sean at Street diesel performance
Ipkyss is offline
post #3 of 8 Old 01-02-2011, 10:41 AM Thread Starter
suban's Avatar
good to know. im pretty sure the minimax only does four at a time but not positive
thanks
suban is offline
post #4 of 8 Old 01-02-2011, 12:20 PM
Yep , mini maxx only does 4 prameters at one time . It doesn't have access to as many parameters as the dashdaq does . if i had it to do all over again i would have sprung for the extra $200 and got the black maxx instead of the mini .
08 F250 Ext. Cab long bed 4x4 Lariet , H&S Mini Maxx , 4" S/S Flow Pro Downpipe ,5" Flow Pro S/S Exhaust ,AFE si Intake , Pro Comp Traction Bars . Kem Mini Maxx 75 through 345 tuning .
wjamesm is offline
post #5 of 8 Old 01-02-2011, 01:02 PM
wired1's Avatar
the reason i went with spartan was the dash daq. i monitor 7 egt,eot,ect,fr pressure, fr temp,trans temp, and boost. and it data logs as well.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #6 of 8 Old 01-02-2011, 02:53 PM
The Spartan (dashdaq) can monitor just about everything that has a sensor. I've never looked for oil press , but I all the others you listed I've monitored with the Spartan. There is one screen on the Spartan that has 12 readouts on it , and they can all be changed to be whatever input you want.
Antonm is offline
post #7 of 8 Old 01-02-2011, 03:44 PM Thread Starter
suban's Avatar
thanks for the help guys. i think the dashdaq is what i should get. i do alot of heavy towing and would like to monitor as much as possible
suban is offline
post #8 of 8 Old 01-02-2011, 04:19 PM
08stroker250's Avatar
The screen that I leave my DashDAQ on has 12 different readings. I think there might be one or two that offer 16 at one time.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
