Have to have tuner for dpf delete? - Ford Powerstroke Diesel Forum
Old 12-28-2010, 08:01 AM
dont have the money to purchase a tuner, but still wanting to put a dpf/cat delete pipe on? on a couple websites it says it is not recommended to run it without a tuner. will this be ok?
Old 12-28-2010, 08:14 AM
shhhhh, can you hear it?
no it is not ok.you will go into constant regen.DONT DO IT.save for a tuner.
Old 12-28-2010, 08:16 AM
know, you do not want to run it without a tuner, u have to reset the regen everytime u get in the truck, if you are on the road you have to stop every 100 miles. save your money up and buy a tuner later, otherwise you will be in the shop, and some techs dont mind modding when it is done right, but if its done wrong, they will deffinately void the warranty.
Old 12-28-2010, 08:25 AM
Flo-Pro DPF Delete Electronics Kit 08 09 Ford 6.4L - eBay (item 300386763547 end time Jan-08-11 20:08:13 PST) cheapest i could find
http://cgi.ebay.com/ebaymotors/Ford-...item1c06d0f840
Old 12-28-2010, 09:37 AM
The truck may go into "limp" mode, causing drastic power reduction, possible shut down. You might be able to find a used setup on here or Kijiji or something.
Old 12-28-2010, 10:04 AM
Negative on running one without a tuner.
Where did you see that you could???
Old 12-28-2010, 10:18 AM
Like others have said, you definitely need to run a tuner. Most of the time if you try to run it without, the truck wont start again after the initial start up once the DPF/DOC are removed. If you wan to do a delete, I highly suggest looking into a quality tuner like H&S or Spartan. Feel free to give me a call or shoot me a PM with any questions you may have.
Old 12-28-2010, 04:15 PM
agreed!
