Best Spartan winter tune
I have been thinking about this for a while. Im currently running the 125 tune now that its cold. Does anyone have any other input as to the best winter tune? I didn't have any problems with the 210 but it broke loose too easy.
With the 125 i find it will build 20-30 psi but not really go anywhere, and I do not have any surging. It is rather strange. Maybe spartan can make me a winter tune? |
bump it up to your 175 tune and see how she reacts to your liking. me personally have ran the 275 for over 2yrs and never had any problem
Ill try the 175. I do not have anything over the 250. i would like to run that or try the 275 but I am afraid of breaking something. Besides I don't have the best tires right now.
![]() ![]() Maybe come spring ill buy the 275 but I am even afraid of that. |
the amount of back pressure they make on the lower tunes (in normal driving) compared to the high tunes shocked me, almost want to jump to a higher tune simply for that.
currently on 125 also |
I run the 40hp tune when it gets real cold and snowy..but most of the time im on the 175.
thanks guys, I think I will try the 175 this week because I may have a 600 mile round trip coming up. It is amazing of how different the truck acts between 32* and say 20*F.
What do you mean difference in temperature? I'm also in Ohio, but I just run mine on the mild. Should I be running a different one?
Well, it runs rather normal around 32*F but once it drops lower than that it will have a tendency to build boost but not really gain any rpm or speed like it should. Such as if you were going to accelerate from a stop.
I also drop to a lower tune to reduce the power and sensitivity of the throttle which I find helps to prevent me from breaking traction. Especially with the tires that i have because they are pretty worn. |
