IC pipe popped off with H&S - Ford Powerstroke Diesel Forum
Old 12-21-2010, 03:11 PM
Got on it hard today for a bit and when I let off....BOOM! IC pipe came off the lower part of the intercooler. I just jacked the clamp down nice and hard but is this going to be an issue? Would a bov solve the problem? It seemed to happen right when I let off. I have been reading here for a while on the 6.4 and haven't seen too many guys with this problem. It runs fine but I haven't run it hard since. Truck is 2010 with 500mi on hot tune.
Old 12-21-2010, 05:20 PM
Once you blow a boot off, you will likely do it again not to far down the road. I would take the boot off, clean the boot and pipe really good, and then put the boot back on using hairspray. Doubling clamping doesn't hurt either.
Old 12-21-2010, 05:24 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
hairspray is a ecellent idea..i use paint and clamp down on her,but when you go to remove it you will dam near have to cut the boot off
Old 12-21-2010, 05:37 PM
+1 on the hairspray, easy on and harder to get off.
Old 12-21-2010, 06:18 PM
I just installed my Mini Maxx and Hot Damn file 3 days and 300 miles ago. I double clamped and tightened those bad boys down at the time of install to prevent this problem.
But, the hair spray is a great idea...wish I had though of that!
Old 12-22-2010, 05:20 AM
does anyone sell boots that are a little longer and slide a little farther on the IC pipe?
Old 12-22-2010, 05:32 AM
You might check with a hydraulic hose shop because their hose can handle the oil and pressure.
Old 12-22-2010, 11:37 AM
I've been very pleased with my DieselSite boots. Others like the Riff Raff boots.
Bob Riley from DieselSite is awesome to deal with also. I blew the upper hot side boot off of my truck one night at the track and damaged it enough for it continue to blow off. I talked to him about it and he sent me a new boot at no charge. Excellent customer service in my book.
Old 12-23-2010, 06:10 PM
paint? really? like spray paint?
