edge evolution racing prog. - Ford Powerstroke Diesel Forum
Old 12-13-2010, 03:55 PM
which setting is best for mpg with this tuner when using it to delete dpf
on 2008 f-350 with 4 10 gears? use this truck to pull gn trailers/camper
Old 12-13-2010, 03:58 PM
Rob Rob is offline
I have the evo race CTS and I find stage 4 gets the best mileage unloaded. However, I wouldn't use that tune to tow. I wouldn't use any higher than stage 2 to be honest. You're gonna build a lot of heat towing.
Old 12-13-2010, 04:02 PM
thanks. truck pulls 10-20 k pounds, so you think 2 is best?
empty truck only gets 11.3 mpg. i also have 2008 f-250 that got 11, then i put sct tuner and cat/dpf delete and it went to 16 mpg. how much better do you think 350 will do with edge on 2?
Old 12-13-2010, 04:07 PM
Rob Rob is offline
Honestly, I couldn't say for sure as I don't tow that heavy. I'd be more concerned about controlling the heat, and stages 1&2 don't build too much heat like 3&4. You should try 1 then 2 and see how you like it.
Old 12-14-2010, 06:13 AM
I have the same chip and am always on 4 with the exception of when towing, then i have it on 2. But honestly i haven't gotten better then 13 MPG ever... i am wishing there was a way to get better with this chip but i don't think thats possible.
Old 12-14-2010, 07:33 AM
I run mine at level 2 as anything higher than that with the 4.10 gears feels like I am going to twist the driveshaft out of it.
Old 12-14-2010, 07:46 AM
Rob Rob is offline
I was just reading on edge's website that When towing with this tuner, it is recommended to be at stage 2 or lower.
Old 12-14-2010, 08:42 AM
Uh how do you know what gears you have? haha sorry newb question but i can't figure it out.
Old 12-14-2010, 08:53 AM
Rob Rob is offline
The gear ratio will be listed on your window sticker from when you bought it, or on the door jamb sticker that has your VIN on it.
Old 12-14-2010, 03:26 PM
thanks for the help, think gonna put on 2 and just leave it
