i normally run the 310 tune as my dd...the first production one. every now and the ill switch to the 275v2 because its smoother than the 310. i switched over to it today and its defueling at half throttle and full throttle. the first time it happened it was at half throttle and i was on an onramp to a freeway. i was in 3rd and it just fell flat on its face. the 2nd time it happened i was at a stoplight and hammered down and right when the tires stop spinning it did it again. any idea why its doing this or how to correct it? thanks
Transmission is sensing slip and sending a signal to the ECM to make the truck defuel....or something along those lines.
this happened me to as well about 2 days ago...what do we do about it Jeff? I was on the 275 tune
Transmission relearn...
Ok, I have a question about the relearn. say I have the tune loaded for a week and finally decided to do a relearn. is that ok? or does the relearn need to be done as soon as the tune is loaded?
Not sure why you would wait a week, but yea you can do it anytime. You could do a relearn after having the tune loaded up a month. It's actually good to do a relearn every once in awhile. Keeps your shifts from getting off. With our TCM, I recommend doing one right after you load a tune. Once you've done that, the next time you do one doesn't have to be as extensive. Just a few hard pulls from 0-60 should be fine. Anytime you load a tune though, you should do some sort of relearn.
some sort of relearn as in a few runs at quarter throttle and half throttle? or? Everytime I load a new tune I do the relearn process correctly.
2 runs at quarter throttle 2 runs at half throttle 2 runs at 3/4 throttle 40 to 70 @ WOT 0-75 @ WOT 2 times. are you saying I dont need to do this everytime? because I really hate running my truck that hard. I change tunes alot |
Anytime you load up a high line pressure tune with the TCM, you should do a relearn. Eliminate the 1/4 throttle runs and eliminate the 40 to 70 at WOT run. You definitely need some 1/2, 3/4 and WOT runs though. |
