DPF back exhaust.
Has anyone swapped their exhaust from the DPF back? I want to get something along the lines of the MBRP DPF back kit, if it will work with my DPF delete, i cant stand the split tip.. does it change the exhaust sound when going to something different or is the "hair dryer" sound still very prominent when driving? links to any videos?? thanks.
You could do a Magnaflow with a muffler. Keeps a throaty sound at WOT, and gets rid of a lot of the hairdryer noise at idle and part throttle.
Got any links to that setup?
Here it is on Xtreme Diesel's site...
MagnaFlow Filter-Back 5" XL Performance Series Exhaust System 16984 It's priced high, but you get both a muffler and a muffler delete pipe in the kit. Someone else may be able to do it cheaper. I got my Magnaflow DPF back exhaust for my delete pipe from Rudy's and it was priced well. |
P.S. I'd buy from Performance Truck Products, Great people and Great prices. |
What size is the down pipe stock? thanks
It is 4", but tis bent in a spot for clearance. Most people just leave it stock.
Where actual exhaust flows it's only 3" in diameter.
It is not necessary for those running regular (not race) tunes. Sure it will help drop temps some, but its not worth swapping out with regular tunes unless you are trying to squeeze every little bit out of the truck. Most people find their EGTs to be very manageable with the stock DP.
