Spartan Mounted!
Like the title says
does it block the speaker at all?
Sweet, I got the same setup. Did you get the "Spartan Mounting Kit" thats really an edge mounting kit with a piece of flat aluminum added?? Or did you just buy the edge mounting pod and figure it out yourself.
Looks great man!
According to most, no. |
I need that lol looks great
Looks good. You also may want to pull your SD card out. Heat can raise he!! on them and I know its probably not a problem now but just a heads up
thx sd card.
just bought the edge used factory bracket does not block tweeter /
it doesn't block the speaker if you are in the driver's side, but your passenger won't hear the highs as well as you can. Not a big deal to most, but I do some pro-audio work on the side, so I notice things like that.
Mine looks exactly the same.
Just be aware if you are leaving it in the truck, the SD card does not like the changes in temps and you will lose tunes. Not really a big deal, you just have to reformat the SD card and load the tunes back on the card. Has happened to me in the past. Just wanted to make you aware. |
I searched for other mounting options without much luck, are there any other options? I just ordered my Spartan and I'm looking for other options.
