Air dog / FASS, are they really needed??
When it warms back up I'm planning on putting on a Titan fuel tank and I was thinking that while I was messing with the fuel system, it would be the ideal time to add an Air Dog or Fass air sep/filter/pump setup. My question is, are they really needed on the 6.4. Will they extend the life of the truck or give me some/any benefit?? And if they are worth doing (neither are cheap) is one superior to the other or is there another one out there that is better?? Thoughs ,insights???
If you are looking for superior filtration, they are worth every penny. I have the Air Dog II DF-165 on my truck and it filters amazingly!
Does it remove all the water from your fuel? How is the install (difficulty)?
Does this replace your current water separator filter?
Yes. The Air Dog II replaces the factory low pressure system and pumps directly to the fuel bowl....which gives you added filtration. |
So with the air dog II there would less possibility of getting water in the fuel system? Is it a job a weekend warrior can do or would a person be better off taking it to a shop?
i also installed the airdog 2 df-165, i did it without removing the bed or dropping the fuel tank, you can reach the draw straw without doing either of the two methods above...
Speaking of fuel, I never drain my water separator anymore since I added the Spartan. Do I need to be draining b/c I never get a message to anymore?
Yes, you still need to be draining the separator.
Thanks Jeff: I drained it today but I didn't see any water in the fuel
![]() I drained it from the yellow valve under the truck on the driver side, is there another area also or is that the only one to drain. |
