Hardware Needed to Install Spartan DPF Delete Pipe - Ford Powerstroke Diesel Forum
Old 12-02-2010, 05:59 PM
Hi, I'm installing my DPF delete pipe and need to know what size nuts and bolts I need. Also I was told that the new Spartan tuner doesn't need the sensors installed in the delete pipe but the pipe I received had a bung installed. What size plug do I need to install to close the bung?
Thanks
Randy
Old 12-02-2010, 09:18 PM
You should not need any nuts or bolts. As for the bung I don't know that one. Get a ratchet strap to help separate and install the two pipes. You will also need a 13 and 15mm sockets.
