About to have ARP studs installed. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-27-2010, 08:10 AM Thread Starter
DLO
DLO's Avatar
Hey guys. The truck's at the dealer needing head gaskets. I'm supplying them with ARP studs in place of the stock crap. Does anyone know the tensile strength of the stock studs by chance? I know the ARP's T-strength is stated to be around 220,000psi. Thx.
2008 350 Lariat CCSBSRW. 18" Monsters, 35" Nitto Trail Grapplers, 4" Superlift, S&B CAI, 5" Stainless Flo-Pro straight piped, ARP Studs, Onyx Head Gaskets Spartan 310
Originally Posted by CobbsDieselPerformance View Post
I am a douche bag, I admit it,......
DLO is offline
post #2 of 12 Old 11-27-2010, 09:40 AM
08stroker250's Avatar
I heard the stock ones were also 220,000 tensile strength.....and I also heard that tensile strength doesn't matter.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 12 Old 11-27-2010, 11:41 AM Thread Starter
DLO
DLO's Avatar
Hmmm....I wonder then, exacty what metalurgic property is responsible for resisting necking or the stretching in the studs, which ultimately causes the heads to lift. I'd be interested to hear what does matter if tensile strength doesn't.
DLO is offline
post #4 of 12 Old 11-27-2010, 01:32 PM
There is a good discussion thread over on PSN in the 6.4L Aftermarket forum that is all about ARP studs vs. Elite H-11 studs. I can't remember what the title of the thread is, but the "search" function should help you out.
Jeff Dodd
post #5 of 12 Old 11-27-2010, 04:39 PM
dieselkane's Avatar
Did you blow your Head Gaskets with the 310 tune?
dieselkane is offline
post #6 of 12 Old 11-27-2010, 05:52 PM
scottbolt's Avatar
Man I am putting the elite diesel towing twins this week on my truck I ask garret at elite if I needed to the same thing cause of the tunes and stuff I had done he said no until you have professional sled pulling power the stock head studs are good as to what garret at elite says!!!
scottbolt is offline
post #7 of 12 Old 11-27-2010, 06:25 PM
Snake's Avatar
Quoted: 46 Post(s)
Head BOLTS (factory) can't be torqued to the same number as head STUDS. More torque on the heads = tighter seal on the gaskets = less likely to blow.
Snake is offline
post #8 of 12 Old 11-27-2010, 07:02 PM
He told you that their tow power turbo's will work without head studs or an EGR delete w/wastegate? That sounds a little far fetched to me.
Jeff Dodd
post #9 of 12 Old 11-27-2010, 07:19 PM
mor4wd's Avatar
It's not about tensile strength, or the amount of torque put on them.
It's about fatigue. Tensile strength is how much it takes to actually break them in two. Fatigue is the amount of "stretch" a bolt allows before failing.
ARP's studs allow much less of this stretching to occur and it's all about the metalurgic properties of that specific fastener. When a head gasket blows, most times it doesn't actually break the studs, the stud just stretches and allows the explosive gasses to get under the head.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #10 of 12 Old 11-28-2010, 08:19 AM Thread Starter
DLO
DLO's Avatar
Dieselkane, The intital leak occured when running the 310. I'd been running the 210 for almost a year with no problems and had just recently retuned with the 310. At first I had a very small leak, visible only by a small stain on the driveway. I took it to the dealer and they said it was the radiator. That was replaced on my dime and on the way home with the new $1150.00 , I lost at least a gallon of coolant on the 10 mile trip. I called again, they sent a tech to my house to look and make sure he didn't F/U something. nothing was found while he was here. The tech drove the truck back to the shop and a few days later i was told that it was the head gaskets. I am having the old radiator pressure tested by a third party, assuming I payed for a radiator replacement that wasn't needed. Still waiting to hear on that.
DLO is offline
