Water/Meth OR: NOS
I am wanting to do one or the other. Ive heard pros and cons of both. All I have is the spartan 310. I am planning on getting a suncoast tq converter and that will be it. Do I need any other mod to run water/meth or nos? and how much hp will each add? Thanks in advance!!
The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
wats the scoop on this set up? |
i know doing water/meth u can pretty much expect a 50-70hp gain when done right, also the water/meth is actually pretty good for your motor contrary to popular believe im not so sure about nos i havent heard a lot about it in the diesel world but normally nos is run by shot or injection pulses normally you buy it by the shot rating which verys from 50,75,100,150 and so on i hope this helps
Do I need any other mod to run water/meth?
not as far as im aware of the kits come with everything u need
all you need to run water meth is the kit and hook to a pressure switch that will turn your pump on and inject it into your intake cools your egts by around 200 degrees, i have it on my truck and like it.
i can try to take pictures of my set up.......................... and i bought from that same company and had no problems, there tech support was very helpfull also when i had questions installin it
how much gain in horse did you see?
not sure really but you can tell when it kicks on i know that
dont waste ur money on meth. it worked well on the older trucks but i'm not happy with mine.
plus if youre looking for power, nitrous is the way to go. |
