Should The Down Pipe Be Replaced?
I am getting ready to install a Black Maxx and looking at going with a 5" exhaust for a deeper sound. I was wondering if the factory down pipe is badly crimped and should be replaced, or if there is not enough improvement to replace it versus expense? I realize it may lower exhaust temps slightly, but didn't know if it would help with acceleration too. Any info would be greatly appreciated!
-Funkster- |
It is a very worth the money mod in my opinion. Only issue is you have to cut the stock downpipe out unless you pull the cab or slide the transmission over some. The install of the 4" aftermarket pipe is not nearly as complicated as getting the stock one out.
If you plan on keeping your warranty, hold off on the downpipe. But if you don't care about the warranty, then the downpipe is well worth doing. Anything you can do to make the truck breathe easier will help make power.
So I guess my next question would have been if the factory exhaust would bolt up to the new downpipe, but since it's larger, that would be a no I'm assuming. that part about it hadn't hit me yet. lol Guess I'll just go with the 5" flo pro exhaust system downpipe back. Thanks!
-Funkster- |
If you have an EGT issue or are trying to get every little bit out of the truck then yes, it is worth it. Most people find it is not necessary to swap out though.
where is the best palce to buy a down pipe and exhaust manifold for a 2008 6.4 diesel ?
Yes, but would the 4" downpipe bolt up to the factory exhaust as well as a 5" exhaust?
-Funkster- |
Yes it has the same bolt on flange!
Chris |
